Heating problem.
(Topic created on: 02-19-2025 08:59 PM)
mks0107
The Samsung Galaxy S24 Ultra exhibits elevated body temperature during WhatsApp video calls. Are there any solutions to address this issue?
3 Comments
GajarkaHalwa
Same
mks0107
My Galaxy A73 model has not experienced overheating to date.
cs_member10
Dear Samsung Member,
As per your concern, we wanted to inform you that using third-party applications and engaging in long game can lead to your device heating up due to increased power consumption. We recommend closing these apps when not in use to help cool down your device.
If you continue to notice that your device is overheating during normal usage, please follow the steps below to troubleshoot the issue:
● Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
