Heating problem
(Topic created on: 04-10-2024 06:42 PM)
abcdroyal
S 24 ultra heating like 15 k price mobile
6 Comments
Lohith2010
It is because of update are not all stable
Shiva0509
My S24ultra is perfectly fine, may be its a software glitch or ur using it outside worb mobile data
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
JithinAjith
Expert Level 3
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
Settings 》Location 》Improve Accuracy 》Turn off Bluetooth and WiFi scanning
cs_member10
Dear Samsung Member,
As per your concern, kindly perform the following steps to resolve your issue by the given links: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
