08-03-2025 08:15 AM in
Galaxy S- Mark as New
08-03-2025 10:39 AM in
08-03-2025 04:21 PM in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that while using camera for recording long videos can cause your device to heat up and drain due to high power consumption. Closing these apps may help cool down the device. However, if you still feel that your device is overheating in normal use, please follow the steps below to resolve the heating issue.
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
08-04-2025 01:11 AM in
08-09-2025 09:55 AM in
08-12-2025 11:05 AM in
