Resolved! Solved
Heating issue while using Camera
(Topic created on: 01-05-2026 06:56 AM)
myname99
Hey All.
Any one facing Heating issues while using camera in S25ultra after upgrade to OneUI8.0
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
6 Comments
calaway
Camera use does cause heat with all the phones as it is a resource intensive app
myname99
Okay. But I feel it heats All the time .Even just I have taken some pics and able to feel heat at camera bumb😊
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
We would like to inform you that using the camera for extended periods, whether for videos or photos, can cause your device to heat up due to increased power consumption. We recommend closing these apps when they are not in use to help cool down your device.
If you continue to notice that your device is overheating during normal usage, please follow the steps below to troubleshoot the issue:
● Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
YjP
Yes. Im facing the issue. Without continuous usage of camara as well in 2 minutes
