Heating and battery drain on s10+
(Topic created on: 03-15-2021 08:14 PM)
sahad
Does anyone is experiencing a battery drain and heating issue after updating to android 11 oneui 3.1. I am experiencing severe heating issue while using normal apps and heavy battery drain also.i am thinking about downgrading to android 10
18 Comments
Ehsank
Don't Do Anything... Just Do..it.. Open Go Your Device Care Setting.. Then Go to Battery Power Mood.. Open Power Mood Set it Medium (Power Saving Mood) Trust Me It Solve 109% Percent Problem & Won't Heat Never Your Device it Never Lag Also (Smooth)..it Works Do this..& You can more things Just Open (App Power Management) right down there on (Power Mood) Option Do (Adaptive Battery) Option Setting Turn On...It Help Limit Battery Usage For Apps That You Don't Use they won't use your battery long time.. One More Thing Open Setting (App That Won't Be Put to Sleep) right down there (Sleeping Apps) Option Set Your Favourite Apps That You Want.. (That Won't Be Put to Sleep) Add Them.. Example Facebook, WhatsApp, Gmail, YouTube, ETC
Follow This
Follow Discretion
Chinkara
I have not received 3.1 on my S10+ as yet. My last update was a patch on 01st February which still shows Jamuary security patch
sahad
which variant is yours . is it indian
Chinkara
Yes Indian
Samsung_Support1
Dear Samsung Member,
Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
sahad
rather than this it is good to switch off the phone. try to give a solution
not to say don't use 3rd party apps or something like that.same 3rd party apps is being used in my a50 android 11 which has no issue
