vijaisharon
Hi in my s21 ultra edge lighting notification except whts app and message rest of apps edge lighting r now black ,
6 Comments
messi6787
first go to notification than in brief pop up setting than in edge light style click on the color and tap on app color your problem will get solved AND MARK IT AS A SOLUTION
vijaisharon
but we will press not will happened, may be 3.1 one ui problem
messi6787
i am not facing any problem after update
Dr_Interchupipi
may be your software not installed correctly ...because that is strange
vijaisharon
bro s21ultra pre installed only
Samsung_Support1
Dear Samsung Member,
Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
