Resolved! Solved
Heating and battery drain issue in S23
(Topic created on: 01-15-2025 01:29 PM)
Royal_RJ
After update in January securing patch update in S23 battery drainage and heating issue is incread in my S23. Anyone else facing the same please confirm me.
2 Solutions
Wodehouse
After you get one UI 7.0 around March you should see an improvement in battery performance and reduction in heat generation. I suggest you wait for this update.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
_Samir
I have updated my s23ultra with January 2025 security patch. Mine is working fine so far.
If you find i have answered your question, please accept it as solution. Thnx🙏
11 Comments
Wodehouse
_Samir
Animesheeb
I am not facing any such issue! Instead I was facing this problem in December but it is resolved now!
Royal_RJ
Ok
Sáyân15
No such issues on my S23. It’s working superb as before...
Royal_RJ
Good for you
mnh
Whenever there is issue with software update . Do factory reset. All issues will be solved
Royal_RJ
Wr😊
