Having glitch while using camera
(Topic created on: 04-12-2025 10:27 PM)
ankitparashar700
Experiencing unexpected color shifts with the zoom feature can certainly be frustrating. A smooth transition in color is essential for maintaining video quality. Further investigation into the cause of this glitch is recommended to ensure optimal performance. Hopefully, a solution can be found to restore consistent color across all zoom levels. This will undoubtedly enhance the overall viewing experience.
cs_member8
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
