Guys, facing problem of slow charging in S20.
(Topic created on: 05-04-2020 02:32 PM)
singh1988
Any suggestions to resolve the issue.
4 Comments
Refund is the only solution.
singh1988
https://chat.whatsapp.com/KcV0FE4xe93Ijxhilae9lZ
Join this S20 users group if u wanna.
Samsung_Support3
Dear Samsung Member,
Please perform the below mentioned steps to resolve the issue:
1. We always recommend to use genuine Samsung charger for charging your device.
2. Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged then kindly visit your nearest service center to get it replaced.
3. Check charger functionality, try to charge your device with some other charger or use your charger to charge some other device.
4. Check charging, if rating is 15W or above. Kindly try to charge the device in a non-inverter socket.
Note: Kindly open Device care from Settings > Battery > Please tap on 3 dots(more option) at the top right hand side > please select settings > enable fast cable charging.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > click on “+“icon > send feedback > error report/ask questions).
