Google play system update problem for s22 series
(Topic created on: 09-06-2023 01:56 PM)
SAURAVMISRA
Is it permanent for s22 series?
Or they have changed the UI for google play system update?
It used to appear as either updated or update available.
But post april'23 update this screen started to appear when there is no update available.
Meanwhile it got updated 5 times and restarted device, but update status is showing for july.
11 Comments
goodthings
My dear switch off device, than try it again. Thanks.
Aashish
Expert Level 4
No problem it's working fine.
Shivam_kr
Latest Google play system is of July 2023 for S22 Series... but in my phone it shows updated to latest google play system.. it doesn't shows like the screenshot u have shared..
Hi this is normal and it'll be fixed automatically from google
sairaml
Restart the device
Update Nahin Ho Pa Raha Hai Sar Kis Tarah Kya Karen
Sar update Nahin Ho Pa raha hai lagbhag 1 Sal se ho raha hai aisaScreenshot_20231221_184542_Google Play Store.jpgScreenshot_20231221_182715_Google Play Store.jpg
SAURAVMISRA
Clear the cache & data of playstore, restart & log back in.
SAURAVMISRA
Clear the cache & data of playstore and relogin. Then check.
