Gap between display and frame of s20 plus
(Topic created on: 12-21-2020 08:01 PM)
Ajaydev
I bought an s20 plus last month. there are gaps between the display and the frame. And it collects dust, but the main issue is I can see diplay light bleeding through the left and right edges of the display and top left corner. Does anyone have this issue? I expected a premium smartphone to be designed seamlessly but I'm disappointed here. Please let me know of anyone has this issue
22 Comments
Furious
if you can attach a picture, it
will be easier to understand the issue.
satyanand7
I bought an s21 last week... there are gaps between the display and the frame.... i ordered replacement then the replaced one also came with the more gaps replay as soon as possible what should i have to doo now
The glue between the display and the body have been melted, I think but, I'm not sure. You may visit a authorized service center of Samsung soon.
assist4tech
Your unit has an issue. The glue has melted. Where did you purachse it from? Hopefully you have not been supplied a refurbished unit.
Notadeveloper
Defective unit, replace it ASAP. It shouldn't happen.
Ajaydev
I purchased it from flipkart, it was not a refurbished product.
Ajaydev
kindly see the photos
Anikroyale
That is the pre applied screen protector, not an issue as far as I can see. Post some photos with display turned off, taken under bright light
Ajaydev
No, the screen protector is far above the bottom of the display. anyway I'll attach the photos as you mentioned, please help me confirm this.
