Galaxy S8 and Note 8 get Dolby Atmos with Android Pie
(Topic created on: 01-24-2019 03:09 PM)
Naveenkumarreddy
 Galaxy S8 and Note 8 get Dolby Atmos with Android Pie Samsung’s 2017 flagships, the Galaxy S8 and Galaxy Note 8, get support for Dolby Atmos with the Android Pie update. Dolby Atmos was introduced to Samsung’s smartphone lineup with the Galaxy S9 when the company finally brought stereo speakers to its flagship line, and we have seen the feature included in many mid-range and budget devices ever since. Samsung also brought Dolby Atmos to some devices via software updates, and the Galaxy S8 and Note 8 are now joining the party as well. Works only with wired and Bluetooth audio The Galaxy S8 and Note 8, like other Samsung devices without stereo speakers, get Dolby Atmos only for wired and Bluetooth audio. But don’t let that disappoint you, as Dolby Atmos is more suited to wired/Bluetooth audio anyway, with the biggest benefit coming in the form of an increase in overall volume output and better separation between the left and right channels. Like the S9 and Note 9, you can choose between Movie, Music, and Voice mode depending on what type of content you’re listening to or just leave it at Auto mode, which automatically attempts to select the best mode for the occasion. To use Dolby Atmos on Android Pie on the S8, S8+, or Note 8, you will first need to have earphones or a Bluetooth device connected to the phone. You can then drag down the status bar twice to access the quick toggles and enable Dolby Atmos using its dedicated toggle. It’s set to Auto by default, and to select a custom mode, you can either tap the Dolby Atmos text under its quick toggle or go into the Dolby Atmos menu in the Sounds and vibration » Advanced sound settings » Sound quality and effects section of the Settings app .
29 Comments
it's ok not a problem you can contact or visit samsung care they will do it through offline .
I think Dubai variants still haven't got pie I
they will get soon don't worry.
arv7801
they are denying as the handset is from dubai, so they are saying flashing indian rom is risky
Ok bro not a problem in Europe it started rolling out today so less than a week it will be in your handed just chill.
arv7801
my model number is g960F for which update has already rolled out.. don't know what is the issue with uae handset's.
I have migrated to samsung after 6 yrs...
hm please wait for some days
shubh18
no dual volte and live focus
oh
arv7801
no update for me yet
hm
