Galaxy S7 Edge Overheating
(Topic created on: 06-11-2020 12:14 AM)
cooldeepak946
Sir I am a big fan of Samsung. Im using now Galaxy S7 Edge SM-G935FD because I love the design.in the March 2020 update with security patch of November 2019 got lots of heating issues while normal using like texting,charging and battery draining rapidly. But before this update everything is fine. Please sir give one big update to fix this serious problem
7 Comments
RJ96
s7 edge is outdated bruh
cooldeepak946
yes it outdated but it is flagship.please fix the heating issues Samsung
RJ96
s7 edge has exynos 8890
Ofcourse its going to heat
its a hardware problem not a software problem
even the midrange chip of qualcomm 712 has better performance.
Its only looks premium
performance is no longer flagship
75bvl
s7 edge didn't have any heating issue before the update
exynos 8890 octa is a good chip which is equal to sd 712 and only after this update the gaming performnace dropped not because of chip and some heating issue.
I will tell you the reason for heating issue.
The cpu in s7 edge is overclocked by november 2019 patch update which created heating issue and throttling problems.
S7 edge's cpu was to be clocked at 2.3 Ghz but they clocked it to 2.6Ghz which is the problem done with software update
cooldeepak946
yes but after this update heating issues is rises too much
Samsung_Support3
Dear Samsung Member,
Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
75bvl
Try to use any custom launcher and use game tuner to get high performance in gaming
