Resolved! Solved
Galaxy S23 ultra battery drain issue
(Topic created on: 04-02-2025 08:38 PM)
Sararhaque
Beginner Level 4
Can someone help me with any suggestion about draining issue of s23 ultra? Recently it drains quite faster. Getting SOT only 7 hours +. Is it ok?
2 Solutions
goodthings
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
4 Comments
goodthings
goodthings
Your's most welcome to here.
Abhay010101
Ohh
cs_member10
IMPORTANT:
• For this:
