03-08-2021 08:49 PM in
Galaxy SSolved! Go to Solution.
03-09-2021 02:39 PM in
Galaxy SHi Dave21
The Galaxy S21/S21+/S21 Ultra utilizes advanced AI-based software to efficiently control battery consumption to match users’ usage patterns. Currently, 5G complies with NSA (Non-Standalone)* standards, which are used in conjunction with LTE and 5G. So 5G and LTE circuits are used at the same time for high-speed processing of large amount of data. It makes that the battery usage time is shorter than and device may become hot than LTE model under the same conditions. If you feel the device overheats, do not use it for a while and wait to cool down the device. If the device continues to overheat, please contact to a Authorized Samsung Service Center with device.
03-08-2021 09:02 PM in
Galaxy SBut alas the OBF period is over now we stuck with it. The phone it's self is by far the best and fastest phone on the market, but with a battery and over heating issue like this....
Apparently the March update fixes all this, I'm praying it does, or samsung does a recall.
5000 mah battery more like a 3000 mah on a good day:(
03-08-2021 09:14 PM in
Galaxy Sthanks for replying.
bruh I hope so too. I'm getting impatient now
03-11-2021 03:05 AM in
Galaxy Sthe way Samsung goes around handling customer services
03-08-2021 09:16 PM in
Galaxy SIf this is true and the March update doesn't fix it, that's what I'll be doing.
03-08-2021 10:11 PM in
Galaxy S- Mark as New
Galaxy SHi Dave21
03-10-2021 08:08 AM in
Galaxy S@Maps_sam07 this is how you lose loyal samsung customers.
By not addressing the actual problem which is the software, let's not talk about 5G and all that nonsense. Fix the issues, this is not a cheap phone and we are not phone illiterate.
Every function should be running at an optimal level be it 5G and the works, why advertise this amazing all day great battery experience and 5G and the bells and whistles 120hz etc etc..
03-11-2021 11:42 AM in
Galaxy SHi Kevinnaick
Samsung is aware of the issues regarding the software of the S21 series device, they will be releasing a new software update soon to fix these bugs. Please keep checking your device for software update notifications.
03-11-2021 11:46 AM in
Galaxy SWe just want what was promised and nothing more nor less and some accountability which is a great start.
Thank you, I check on the daily for that update.
