Resolved! Solved
Front camera issue
(Topic created on: 07-03-2025 02:53 AM)
nonameforu
Beginner Level 4
My s24fe seems to have a problem
Suggest me a way to fix it
When recording front facing video the video is darker when shot at 60fps and is true to colour at 30fps (during night)
I havent noticed much change during day but still there is a color diff
Please help
2 Solutions
BiRdMaN
It is a BUG send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful please Accept it as a solution Thank you 😊
goodthings
6 Comments
BiRdMaN
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Kindly check the physical condition of your camera lens, such as broken camera lens or scratchy camera lens.
● Kindly camera lens cleaning: Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
Bsohel
😂😂😂😂😂 I can help u.......hahaha😂
nonameforu
Beginner Level 4
How tell
