Frame problem
(Topic created on: 03-28-2025 03:53 PM)
SAniloy
It's been a month since I've been using a Samsung Galaxy S25 Ultra. I also use a silicone case for safety. Yesterday, I was cleaning my phone and noticed some scratches on the phone's frame. Has anyone else experienced this problem? Is that scratches or something else
21 Comments
MdAmashshams
Pata nahi yrrrr....ye Samsung waale ab kya kr rahe hain
Ye frame pata nahi aisa q ho gya hai
But bro aap isme back membrane laga lo jo ke aap ke back me saath saath frame ko bhi protect krega is type ke problem se
7533998k7
93🙏w
MdAmashshams
Which cover are you using would you like to share
SAniloy
😊20250328_165106_1000020685_1743159223.jpg20250328_165100_1000020684_1743159244.jpg20250328_165029_1000020683_1743159257.jpg
diwankaifkhan
Bhai Anytime back cover lgane se aisa hota hai dust jo ander hi fasa rhta hai wo kuch samay baad dent aa jata hai mobile pe ...
So iska solution daily ek baar back cover nikal kr cotton se saaf kr dijiye mobile or back cover ke ander ke side ko ..so ye problem nhi aaega ...
Or back skin bhi lga lijiye transparent wala 👍👍
SAniloy
Is there any way to remove them?20250328_162126_1000020688_1743157388.jpg20250328_162121_1000020687_1743157388.jpg20250328_162111_1000020686_1743157388.jpg20250328_162138_1000020689_1743157387.jpg
diwankaifkhan
Mobile cleaner spray try krna brother shayad remove ho jaye ...
But jyada gahra dent hoga to fir mushkil hai brother...
kitna time tak countinuesly back cover lgaye the ?
Darkvader12
Expert Level 3
If it if permanent then forget about it
SAniloy
That doesn't seem permanent. I've been using this cover since I bought my phone. Today, I was cleaning my phone and saw those things.
