Frame drop issue
(Topic created on: 01-27-2024 05:49 AM)
Sougata16
When I play EFootball 24 in low graphics setting in 6o fps,at the time my screen refresh is 120 hz but still i see frame drop in the game & gpu use that time only 24 percentage.
Want to solution from Samsung
SD888
3 Comments
JSS28
Samsung phones are usually not good in games though
But still for SD 888 its weird
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that EFootballis a third-party application, kindly contact the particular application helpline to make sure there is no issue from their end.
If the issue persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
nikhilas
I'm also facing same issue only wile playing football game
