Found the solution for the problem in s22ultra battery backup problem
(Topic created on: 10-09-2022 08:39 PM)
visgu
As you know samsung s22ultra uses latest ltpo display which can adjust it's refresh rate from 1hz to 120hz, that's screen is just brillant and better than any other smartphone falling in same price range but the problem is though it can variate to 1hz to 120hz the phone software never allows to ffalling blow 24 hz when phone is not used so because of that the screen time is not getting any better after many software updates
13 Comments
S_Kumar73
So? Where is the solution?
visgu
How should we know that
S_Kumar73
Ur title says found the solution. That's why I asked like that. You mY say you found the reason for battery drain
visgu
Samsung have to help us
S_Kumar73
I lost the trust.
visgu
Bro it's my mistake i said i found why it was happening
S_Kumar73
TSeries
Battery life depends on the user.
If you give me your device I can get 12 Hr SOT. You have to know how to use it to maximize SOT without sacrificing a lot.
I've S22Plus and with 120Hz I'm getting at least 10Hr SOT. With 60Hz 12 Hr SOT.
visgu
I bet you you can't take out that much are you even talking just watch your number 12hrs screen on time,are you high on something bro
