Fix camera and display
(Topic created on: 02-25-2025 02:31 AM)
myselfadil
At this point i feel frustrated with camera performance sometimes like samsung has good cameras still not fixing noise theirs a lot of noise on images took in s24 ultra and dont know why and seriously its a fact that s24 ultra display has a very big issue and processing is much good in s23 series than s24
Also felt display issue of s24 still not fixed and no one is talking about that s23 display and s25 also better than s24
Fix camera and display!!!!!!!
And in this point of view sad to say iphone wins in lowlight as their is full of grains in s24 now we take a picture in normal light their will be grains so i feel samsung needs to improve its camera its only gud in processing pics with nice light and dynamic range frustrating
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving your device issues. We are taking your feedback regarding this matter and will take it into consideration for future updates.
1. Galaxy device camera issue: ● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
1. Galaxy device display issue: ● Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off. Kindly power buttons on the device after by pressing power for 5-7 seconds.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
