2 weeks ago in
Galaxy S- Mark as New
2 weeks ago in
2 weeks ago in
2 weeks ago in
Galaxy SDear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
2 weeks ago in
Galaxy SHi,
I am using Samsung S24 Ultra and Unable to use even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become Dim after that it will become Normal only after you go it Indoor..
I am facing this issue since many days tried lot of Solutions suggested by Samsung team in Samsung Community forums like Reset, applying adaptive Color tone,.....etc., but this problem was not fixed
Finally last week I visited Samsung Service Center, they tried :
1.IQC---No Problem in it,
2.They Done Software for it---Unable to fix the issue
I was really vexed of trying all these and not getting any solution for the above Problem..
it's Big Issue in a Flagship Mobile But Samsung was Unable to fix the issue
Buying Mobile for Lakhs of rupees But Unable to Use it even 10 Minutes in Sunlight Displayyyy
So Dissappointed for Purchasing Samsung S24 Ultra with above issue..
a week ago in
