Fingerprint is not working properly.
(Topic created on: 09-27-2024 01:18 PM)
Rohit_jdee
I am using an S23 FE and am experiencing a recurring issue with the fingerprint sensor. Whenever I attempt to unlock the screen using my fingerprint, it often fails to recognize it. Out of every five attempts, it only works once. Can anyone suggest a solution to rectify this problem?
11 Comments
cs_member10
Dear Samsung Customer,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Fingerprint sensor not working
If your fingerprints fail to unlock the phone, and you are asked to type in the lock screen password, follow the steps to resolve the problem:
Have you check your fingers:
Ensure that your fingers are clean and dry.
Note:
1: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
2: If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
Clean the fingerprint sensor:
Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize fingerprint.
Remove the Screen Guard /Screen Protector:
Samsung cannot guarantee compatibility with third-party products, as the thickness and structure of protective films or screen protectors may affect the performance of the fingerprint sensor. So if you are using third-party Screen Guard /Screen Protector remove it and try re-registering the fingerprint again.
Remove fingerprint and set up fingerprint again:
Remove the current fingerprint and set up fingerprint again. When you touch the sensor to set up fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
Please follow the below steps:
How to remove Fingerprint:
Navigate to apps screen and tap on Settings>>Tap on Biometrics and Security>>
Tap on Fingerprints>>Tap on Fingerprint1>>Tap on Remove>>Tap on Remove again to confirm.
How to Set up Fingerprint:
Navigate to apps screen and tap on Settings>>Tap on Biometrics and Security>> Tap on Fingerprints>>Tap on Add Fingerprint>>Scan your fingerprint>>Place your finger on the sensor, then lift it off when you feel a vibration>>Tap on Continue>> Reposition your finger each time to capture the edge of your fingerprint>>Tap on Done>>Fingerprint added successfully.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
You can reset your device by following the steps.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
Samsung Customer Support.
pilotsandeep
Just try once by putting your device on
" SAFE MODE " see if it works.
To enable Safe Mode on a Samsung phone, you can do the following:
1. Turn off the phone
2. Turn the phone back on When the Samsung logo appears, press and hold the volume down button
3. "Safe Mode" will appear in the bottom left corner of the screen
