Fingerprint Biometric Problem
(Topic created on: 04-15-2026 01:09 AM)
MrAshu01
Not working samsung s24 fe finger Biometric
To before half hour mobile is Update
Than fingerprint work properly but after some time
Again same problem which is related from last 2 week
Why
Please suggest me
3 Comments
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
● Ensure that your fingers are clean and dry.
Note: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
● If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
● Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize the fingerprint.
● Remove the current fingerprint and set up the fingerprint again. When you touch the sensor to set up a fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
● How to remove Fingerprint: Path: Settings> Biometrics and Security> Fingerprints> Fingerprint1> Remove> Remove again to confirm.
● How to Set up Fingerprint: Path: Settings>Biometrics and Security> Fingerprints> Fingerprint> Scan your fingerprint> Place your finger on the sensor, then lift it off when you feel a vibration> Continue> Reposition your finger each time to capture the edge of your fingerprint> Done> Fingerprint added successfully.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
