Fast charging does not work on S7 edge
(Topic created on: 04-27-2018 05:20 PM)
VinodhRajah
Fast charging doesn't work always. It shows 'Fast charging' but doesn't charge fast. I tried with a new original Adaptive Fast Charger, still doesn't work.
10 Comments
Not applicable
change the cable bro
VinodhRajah
Not just cable, I bought a new charger.
Not applicable
see sometime charger is not responsible all the time try changing the cable even I had too faced this problem in a5 2017 which was my previous model and this problem was also continued on my s9 so I changed the cable first time I thought that it is problem of my phone better later on I switched to micro usb using the type c otg it worked
VinodhRajah
Thanks mate! It works. Interchanged my 6 months old charger brick with the 2 days old brick's cable. I don't get the logic but works :)
Not applicable
ok
ashu56
change the cable .
charger isn't main victim in 90% cases its cable
VinodhRajah
Right. I wonder why the new charger didn't work too! But anyway I interchanged the old one with the newly bought charger's cable. It worked. Thank you :)
ABDEVILLERS
try in cold temperature
using fast charger causes warm
and now in India hot climate
so if you are in ac or cooler then plug and charge it will charge faster
OntheEdge
*try in safe mode..**Also enable fast charging under battery settings. Read the charger if it states Fast charger.
