Facing issues while configuring Intelligent Hub
(Topic created on: 11-16-2021 08:54 PM)
UmeshKr001
I am facing the attached error while configuring Intelligent Hub on my Galaxy S21 Ultra. I was able to use the application before upgrading to Android 12 beta.
4 Comments
UdayveerSingh
Are you still on beta? If yes, then please update to stable version, and see if it helps.
UmeshKr001
My OS build starts with SPA... I think I am using stable version but facing same error.
UmeshKr001
Might be the application issue... will take up with concerned team.
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please perform the below mentioned steps to resolve the issue:
* Check app cache: Clear cache memory of a particular application: Setting >Apps >Now pick the app. For example 'Samsung Internet' >Storage >Clear Cache.
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
