09-29-2025 07:52 PM in
Galaxy S- Mark as New
09-30-2025 02:50 PM in
Galaxy SDear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● The proximity sensor is located at the top of the phone, although the exact position will vary by model. Clean the front of the device with a clean, soft cloth.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
