Facing display Issue in my S22 ultra
(Topic created on: 07-12-2023 11:47 PM)
babumosai
A specific portion of the phone’s display turns white, permanently or semi-permanently. In other words, this section of the screen remains white rather than displaying the content. This white patch appears on the left-hand side of the front-facing camera, rendering it unusable.
12 Comments
babumosai
Has anyone else having the same issue?
john163
try to lower the refresh rate and reboot the phone..saw sometimes this is a temporary fix
babumosai
Yes, it did work but I hope it works on adaptive mode too. Thank you!
I would suggest you to visit service center
babumosai
I went to service center, they suggested to change screen but would cost $250.
Sam7000
This problem is due security patch update , s20 , note 20 and s22 series having display problem, but thanks to samsung that it replaced display frame and battery free of cost to me, and my mobile is out of warranty
swapan1997
Which device you have
Sam7000
Samsung note 20 ultra
babumosai
They won't do a free replacement for my phone, since it's out of warranty now. Though it's been 1yr and 2 month since the purchase of my phone.
