Facing audio delay in S23fe.
(Topic created on: 04-23-2025 10:50 AM)
singh2508
Facing audio delay in S23fe whenever I play youtube and my earbuds are connected. On phone speaker , there is no issue at all but as soon as I connect my earbuds there's a little lag in the audio and video. I have checked my buds with another phone but there was no issue at all. So it might be some bug or some setting that I have changed and no now i am not able to enjoy the content. If anyone knows the solution. Let me know.
cs_member10
Dear Samsung Member,
● Kindly check headphones once by using ''another application''.
● Please check another headphones with same device or same headphones with another device to verify.
● Check the device once after clearing Youtube application data.
Path: Settings > Apps > Youtube > Storage > Clear Data.
● Kindly check the device once after updating the Youtube application.(If update available).
● Kindly uninstall the Youtube application and reinstall the app.
● Safe Mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
