Facing Issue In Charging
(Topic created on: 08-24-2023 11:51 AM)
Tarun_Singh1998
Hey,
I am using S22 Ultra & 45w official charger of Samsung, I am facing issue that after charging to 97% my phone automatic connecting disconnecting charging...
Screen Recording attached
13 Comments
Please restart once & check
* note please check charger connection also
ALREADY DONE BOTH THINGS
Without checking the device nothing can be predicted now ,
Please visit your nearby Samsung service centere
Devv_007
It could be an issue with your charger,battery or USB port ,so I recommend you to not charge your phone past 95%.And you should visit service center.
trilokk
I kept phone side type c inserted and charger side inserted in new 45W charger it kept on showing like above video. But I removed it and inserted in old 45W charger it worked without any issue.
umesh30
I recommend you to go to Samsung authorised service center...
lakshay13
I faced same issue go to samsung service center and tell them to clean your charging jack book its done . This usually occurs due to dust in charging jack
trilokk
If it's dust it will not charge with old 45W charger or other 25W or 15W charger.
But 0% to 95% there is no issue like this
After 95% issue started
