FM Radio isn't working with Type C cable or Headphones
(Topic created on: 08-03-2023 01:27 AM)
MHTAREQ
I got a Samsung S21 5G (Snapdragon 888) from Japan (SM-SCG09), and strangely FM radio does not work with the original USB-C or AKG Headphone (they sound amazingly well, let me say, with digital formats, YouTube, etc), but when I turn on FM radio the app throws a message sayin' that these earphone can't be used as antena.
10 Comments
umesh30
Have you bought type C headphone from Japan?
MHTAREQ
I purchased it (akg) from official samsung store in Bangladesh
samfan91
Buy type-c to 3.5mm adapter and use any normal earphones with 3.5mm pin.
MHTAREQ
Its working bro 💪
Thank you 😊
cs_member8
Dear Samsung Member,
Greetings from Samsung Customer Support
We acknowledged your query and want to know you that this is the concept of the device you have to use the Type C to 3.5mm cable to use the FM radio with type c headphones or earphones,
Samsung Customer Support.
MHTAREQ
Its working bro 💪
Thank you
sandeep4606
which dongle are you using bro
AJca999
 Hello, am Carl
I have same problem. Original akg headset works for music, but for fm radio it shows not compatible headset. I tested it on 2 s21 phones.
I got c type to jack converter. I can listen to audio and music but also it does not work for radio. Please i need to make it work. Help please.
Thank you
tatakeo
I have samsung galaxy quantum 2 (snapdragon 855+) and my type-c earphone doesn't working on fm radio .....
