Estimated capacity of S20 FE battery
(Topic created on: 10-05-2021 12:40 PM)
UnicornZ
Hello Everyone,
Bought Samsung S20 FE 5G couple of days back and this is my first Samsung flagship. For last 7 years I was into OnePlus flgaship's. So trying to adapt to one UI and lot to learn. I have a question. I rely upon accubattery for the battery stats and I charged my phone oly thrice so far. After first charge, battery's estimate was at 99%. After second cycle, it was at 92%. Now today after 3rd cycle it gone down to 90%. May I know is this normal. I found accubattery stats to be true all the time. So kind of worried if I need to replace the mobile. Please share your thoughts.
6 Comments
Probably it hasn't calibrated Probably, since it is only 3rd charge cycle ,
You Can Use Diagonostic Tools in Samsung Members to check if there a issue with Battery
UnicornZ
Thank you for the response. Appreciate it.
kosika
#spoiler
You will get to know about the device very soon
Samsung ui hasn't been the same it used to be
Battery drain issue are occurring after one ui 3 lacking proper optimization.
This has been the case for very flagship to budget phones.
Yes your device might be having drain issue as all others are noticing it slowly.
You should continue to compromise in battery life until Samsung improves optimization. Till now Samsung hasn't been responsible about these issues. It just doesn't care customers
S20FEGUY
I had made a post to not buy this rubbish device during the BigBillion sales. Even after that they buyed. Just wait and watch 😂
S20FEGUY
I can see you have manually typed the design capacity to 4500mah. It should be 4370mah.
Then, it should be showing battery health to 94-96% approx bcz that what it is showing in my device from day 1 and it's 6 month old. Try to update me.
Dear Samsung Member,
We acknowledge your query and apologize for the same. We would request you to register your concern in Samsung Members Application. So, that our concern team gets back to you as soon as possible.
Please follow this path to register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Note. please attach the error log file within 15 minutes of the error occurred.
