Edge screen light notification not working
(Topic created on: 05-14-2017 10:12 PM)
Rizwan3
8plus edge screen is not getting lit up when notification comes in.
5 Comments
shazy1
same problem... what should i do?
Hassaman
I think the feature had been removed
Rizwan3
i contacted samsung support. they told to check in safe mode and it worked. it looks like some applications are blocking this feature.
adhi1
same promblem occuring what should i do to light up
Rizwan3
go to display settings and enable edge light. u can contact Samsung chat. they are very helpful.
