10-22-2024 12:08 AM in
Galaxy S- Mark as New
10-22-2024 07:31 AM in
10-22-2024 08:50 AM (Last edited 10-25-2024 09:41 AM ) in
Galaxy SDear Samsung Member,
● Clear app cache through Device care:
→ Settings > Device care > Storage > CLEAN NOW.
● The clear cache memory of a particular application:
→ Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Kindly perform the following steps to enable and set it in the Notification settings after performing the above given steps.
→ Path: Settings > Notifications > Notification pop-up style > Edge lighting style > Select Effect, Color, Advanced > tap ‘Done.’
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
10-22-2024 12:07 PM in
Galaxy SBut problem still persist.
I tried what all you mentioned.
Can't factory reset my phone coz lots of data, and I recently purchased it, 1 week old only.
But tried all other option u mentioned.
It's updated too.
