a month ago in
Galaxy S- Mark as New
a month ago in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that we never recommend downgrading your device software as this may cause malfunctioning on your device. However, kindly share the log file if you are facing the issue after getting update. Also, share the same images for better understanding. This will help us to investigate further and resolve this issue.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
