Sanju541990
02-05-2026 11:46 PM in
Why the edge panel in Samsung is so massive in size .. the app icons are too large and also the panel size is too big to accommodate such a small number of icons. Is there any trick to reduce the size or having a vertically scrollable single column edge panel.
2 Comments
Retrograde
02-06-2026 01:09 AM in
Samsung did make the Edge panel feel chunkier in recent One UI versions.The big icons + wide panel are by design, mainly for touch accuracy… but yeah, it wastes space.
Sanju541990
02-06-2026 01:50 PM (Last edited 02-06-2026 01:50 PM ) in
But Samsung should provide an option to change the size of icons and panel width and height. Also, it will be much better to provide a single column vertical scrollable panel - at least via good lock customization
