Dual audio is not working
(Topic created on: 05-07-2024 09:53 PM)
Hisham03
Beginner Level 3
I can't able to select both wired and wireless headphones at same time on my S22 plus. Help me to resolve this.
#S22 #S22plus #samsung #issue #Dualaudio
4 Comments
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that this is the concept of the devices, and it is not possible to use both wired and wireless headphones at the same time on your phone. You will need to choose one option to use at a time.
You can switch between wired and wireless headphones by unplugging the wired headphones and turning on your Bluetooth to connect your wireless headphones. However, If you have other concerns regarding Samsung products kindly feel free to get in touch with us.
Hisham03
Beginner Level 3
Hi, Thanks for your reply. But this kind of feature is available on chinese phones. Why can't Samsung do. I request to add this feature in future.
uniceak
Not in Chinese phone. It's possible in some samsung phone
uniceak
You're saying lie .in some a series and s series able to use dual audio then update come and destroy it.
