Does using Modes and Routines drain Battery?
(Topic created on: 09-22-2024 08:48 AM)
TheTech
I am using Modes and Routines to save battery drain overnight by enabling power
Saving mode
But it seems draining a lot battery
14 Comments
ch4A
Yes, it decreases.
TheTech
Ok
Thank you
It doesn't usually consume more than 1% over 100% charge cycle. U need to check other issues.
TheTech
Over night Battery drain is around 4 to 10 percent
But when I enabled it
It drains similar
Pls share screenshot of battery consumption apps in device care. If battery drain is same after using modes & routines, something else is the issue
TheTech
Well I deleted every Routines except full Battery announcement
Ok, check out battery drain in airplane mode and report back
TheTech
Ok
TheTech
I checked for a while and it didn't drain
