Does powerbank gonna destroy my s8 plus battery?
(Topic created on: 03-06-2018 09:17 PM)
Nishant120695
I have a power bank of Ambrane which is 20800mAh in capacity. It has Output 1-> 5V=1A, Output 2 & 3-> 5V=2.1A.
I use my Galaxy S8 plus on output 2 or 3. My device charges well. The only difference is that I don't get fast charging instead I got a warning message once 'Slow charging make sure your device is connected properly'. Slow charging continues after clicking on 'Ok'. Now I make sure that device is properly connected.
I just wanted to know that is it okay to use my device with this powerbank or it will have a bad impact on my device battery strength & life due to slow charging with powerbank ?0711145f-dd2d-4756-8ae1-72bdd4b75044.jpg
6 Comments
Gurpreet61
purchase MI power bank
Âquaman
dont use cheap powerbanks
SabirMomin
use mi powerbank I used mi and it support fast charge also best powerbank available in market.
admin_
Thanks for reaching out to the Samsung community! Samsung recommend using Samsung approved accessories with the device. Regarding the charging power compatibility the power required by the device must be compatible with the charging power bank. Using third party accessories may affect the device performance.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Aryanshaikh
https://youtu.be/UnkJ8hnggvw
dineshraj
Hi.
I received gift of Samsung power Bank.
Even after 10hrs charging also not charged fully..
it is power bank problem?
