Does S23FE Heats While Using Samsung Dex
(Topic created on: 10-09-2024 01:30 PM)
Exynos9611
Does Samsung S23FE Heats While Using Samsung Dex Mode Or Not Or Theres No Heating Issues And Can We Play Heavy Games On S23FE By Using Samsung Dex Mode
5 Comments
RICCMMAN
I wonder why people buy exynos variant 🤔 #teamexynos #whyexynos
A bit it gets heated
Exynos9611
but how much
Depends on yours phone usage
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. While using games and dex services are power-intensive and can cause device to heat up, especially during extended use. Closing these apps may help device to cool down. And, you can use the Model S23 forgaming, It's normal for every device to heat up during game or using apps on normal tempreture but if you are feel more then heating in your device kindly follow the below steps to resolve your device issue.
1. Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
2. Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
3. You can reset your device by following the steps.
