Distortion/crackling sound from upper speaker.
(Topic created on: 10-02-2022 10:37 PM)
PRASSANTH
While taking calls in speakers upper speaker at full volume upper speaker is distorting. Anyone else facing  this?
@S21fe
5 Comments
Grizzlygoon
I'm getting a crackling sound when I switch on the front camera. S22 ultra. I have the October patch. Not sure if it's because of that
PRASSANTH
Brother I got new one and directly installed October patch so not sure about the issue is in hardware or software and one more thing are u getting frame drops in day to day usage after October patch?
Grizzlygoon
Haven't checked frame drop. I'll check and tell. But no noise cameras on your phone? A small sound when switching cameras??
PRASSANTH
Mine is totally fine while switching cameras only problem is laggy ui and distortion from speakers.
cs_member8
Dear Samsung Customer,
1. Disconnect anything plugged into the headphone jack like a selfie stick, headphones, Bluetooth, etc.
2. Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
3. Check device volume settings:
Apps> settings> sound & vibration> volume> Drag the volume adjustment bar left or right to increase or decrease the device volume.
4. Check mute all sound options:
Apps> settings> accessibility> hearing enhancements> Disable mute all sounds (if enabled).
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Ask question).
Thank you for writing to us.
Samsung Customer Support.
