Resolved! Solved
Display problem
(Topic created on: 04-23-2026 11:26 AM)
yusuf1804
I have display issues in my galaxy23+ i.e. a line show in display .
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue. Then go to service center for replace/repair it's. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
4 Comments
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Kindly restart your device.
● Update software on device: apps screen > Settings > Software update > Download and install > Download > Install now.
● Reset the device:
Note: Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite. Remember Google password before resetting the device because it required during initial setup. If you don't remember the password, then reset (Forgot password) your google account.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > Factory data reset (This will erase all data, including files and downloaded apps.)
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
yusuf1804
I have completed all given instructions. However, the intended result has not been achieved, and the issue persists.
