Display problem
(Topic created on: 11-02-2025 09:09 PM)
riyaj4455
Samsung company gives 5 years of updates but my mobile has a green line on its display. It has been two years since the mobile was last updated. What is the solution for this?
2 Comments
KunteAmith
So if your phone is eligible for display replacement you might get it under warranty check with service center. If not then you have to pay for replacement.
2nd option is 3rd party display repair service that might be able to fix green line issue but no guarantee. Green lines are hardware issue and no updates can fix them.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit the service centre and inspect your device with the technical team end, they will provide you with all the information in a better way after inspecting the device physically.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
