Display problem
(Topic created on: 04-16-2024 07:09 PM)
karthikrishna95
Suddenly pink line appered on my phone's display
4 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue. Then go to service center for replace/repair it's. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
Which phone you are using? Is it still in warranty?
cs_member10
Dear Samsung member,
As per your query, kindly follow the easy troubleshooting steps which might help to solve the issue.
Power OFF Galaxy smartphones and turn ON-
To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Samsung Customer Support.
