Display orientation problem with S21 FE after Android 13 update.
(Topic created on: 12-17-2022 02:21 AM)
Rakeeb
I am facing wrong orientation (portrait mode/landscape mode) issue very frequently after Android 13 update with my S21 FE. Applications like Camera, Gallery, YouTube or other 3rd party apps are not acting properly with display orientation.
 - If I take pictures, they are upside down.
 - If I play YouTube video in full screen mode, it's starts at upside down orientation. If I rotate my device to match the display, it rotates again and go back to upside down orientation.
In my opinion, it's system issue as most of the apps (system + 3rd party) are facing same problem after update.
Please resolve this issue. This is very annoying. Thanks for all the support. 👍
14 Comments
Ratnodeep1986
Recalibrate gyro sensor
Rig
How to do that ?
Ratnodeep1986
There is an app in play store
vishalparihar
Beginner Level 4
Ya same problem in note 20 ultra after updating to android 13
Subrat007
Beginner Level 5
I am also facing the same problem after ONE UI 5 on my slS21 fe5g, hoping Samsung will solve this issue in next update
This is very annoying for everyone
Rig
Same issue for me also
Himanshu_9356
Beginner Level 3
I am facings camera orientations issues in S21 FE after installing android 13 upgrade
cmohan85
I am also facing same issue after android 13 update on s21fe 5g
Himanshu_9356
Beginner Level 3
Restart phone once
