Display issue after upgrade
(Topic created on: 05-26-2024 06:19 PM)
ruman02
Beginner Level 3
Not sure how but for the very 1st time post upgrading to one ui 6.1 my screen / display started flickering and the next min I see half of my display seems burnt and a yellow stripe along with black lines started appearing on my screen.
Is this related to samsung screens like how oneplus had issues.
Pin the post if anyone else facing the same issue.
9 Comments
Nobyos
Device ...
Xpressnote
Rohit_S22
Raise complaint
Rohit_S22
We are support all user that are facing issue like this.
ROZAJMERI
I am a pure sumsung coustemer from 2000 when gsm phone with entina till 2024 i am still using sumsung in the year but now after using sumsung from 20 years i am never dissappoint from sumsung but now i am very dissapoint to say that i own and trustable company has fraud me .my sumsung s22 has a got a green line after software upate i am very sad to say that samsung has disappoit me after using sumsung from 20+ years this is sad moment for my life i request you to replce or repair my device because i could not accept this kind of things with pure sumsung couatmer and it is not only me but many other coustemrs have this problem and i am very sad to say that if this kind of behavior contines we people from samsung family needs to leave the samsung family and use other phones we are not at all happy to leave this company at all and this is not are fault at all its your company fault and only you are 100% responsible for it if the software is not ready to use company should not upade the mobile company should cheak the upade with responsiblity in upate 16.1 One UI Version problem i was using m200 galaxy Y galaxu y duos R200 galaxy grand ,grand2,j7,j6,,s3,s3 mini ,A50,A53,A52 wifi 6 S7 Mini , S5 , Galaxy F ,Samsung Guru keypad mobile and many more but after many years i do not rember some of them but i am never dissapoint with any of them but this s 22 ultra has got a green line after upade . But i am very sad to say the samsung is nowdays is not giving value to coustmers but giving importance to money and thinks to make company more profjtable we the people of india takes coustemers as god and happiness is only we need and try to stasify it thats all we dont give the pripority to money on coustmers we are not willing to defame the company but my friends were telling not to buy samsung and my trust on this comoany has been removed
I am very premium coustmers of samsung for more than 20 years but i am giving this in writing .i with my s22 ultra upated software after mobile setup till 100 % when optimisng finished when switch on the phone green line came after line i shut down the phone 2-3 times and it was biggest fault that i upaded my phone
Dont parchese samsung S seris phone
S22 ultra s23 ultra s24 ultra all model probleams
Dont update ONE UI Version 6.1
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Kindly restart your device once: To power off through Quick settings, swipe down from the top of the screen. Tap the Power icon in the upper right of the screen (next to the Settings icon), and then tap Power off.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
RAMULTRA24
Hi,
All S24 Ultra Users once check below Issue mobile once.....
I am using Samsung S24 Ultra and Unable to use even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become DIM after that it will become Normal only after you go it Indoor..
Unable to Use it even 10 Minutes in Sunlight Displayyyy..
Even we checked in My friend's S24 Ultra, Similar Issue in that Mobile also....
it's BIG ISSUE in a Samsung S24 ULTRA Flagship Mobile But Samsung was Unable was not taking this issue very Seriously and Fixing it !!!!
This Issue is Not there in S23 Ultra and it's Display is best than S24 Ultra...
Even 10 thousand mobile we can use as much as time in Sunlight and it's Display is Super in Sunlight...
But Purchasing S24 Ultra Flagship Mobile of Samsung with Lakhs of Rupees But Unable to Use for even 5 minutes in Sunlight...
Immediatly Samsung need to fix this or Recall All S24 Ultra mobiles to fix this Issue in Mobiles
If Samsung Unable to fix this Issue, It need to Refund all the price of the Mobile to effected S24 Ultra mobile Users...
Adusparx
Same thing happend to me on my S22 Ultra after the One UI 6.1 update. Did this get fixed?
Tusharkale11
Beginner Level 4
IMG-20240728-WA0005_1000342651_1722183104.jpgIMG-20240728-WA0004_1000342648_1722183101.jpgIMG-20240728-WA0003_1000342645_1722183098.jpg
