Display Quality issue in s25+
(Topic created on: 02-21-2025 11:59 PM)
sagar_blank
Do anyone else facing greenish tint on their display while watching youtube or netflix.
Also dark theme as geryish look rather than deep black. While watching video also, you notice deep blacks are missing and it looks are colors are not deep and has a hue layer all over.
Also display doesn't gets fully dark while watching deep black content as an good amoled screen should.
Please let me know if anyone else notice such things.
Thanks
3 Comments
sag120667
How super amoled displays work is when there is something dark/black, it would shut down(turn off) those pixels of the screen. That is how pitch dark is achieved by amoled.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
sagar_blank
😂 Already raised the issue with Samsung about my s25+. They told me after 10days and 5 days of device holding at service center that device has no issue and this is common for all units.
It means if Samsung used poor display in all units it's not there fault you should have checked before buying. 😂
Aah one more service center after holding for 5 days gives back device scratched, battery 0%.
I will now Never trust Samsung nor buy nor suggest to anyone to buy. 🙏🙏🙏
