Difference between enterprise edition and normal edition
(Topic created on: 11-21-2024 04:44 PM)
LOKESHTEJAVATH
Hi, I'm planning to buy S24 ultra, I see the company I'm working with has corporate discount for S24 ULTRA enterprise edition, but I'm not sure if the enterprise edition will have any restrictions about the apps installation or any such things
4 Comments
Wodehouse
The Samsung Galaxy S24 Ultra Enterprise Edition is designed for business use, with a focus on security, management, and productivity. While it's based on the standard S24 Ultra, there are some key differences to consider.
*Key Features and Restrictions:*
- *Security:* The Enterprise Edition comes with additional security features, such as Samsung Knox, which provides a secure environment for business data and apps.
- *App Installation:* The Enterprise Edition allows IT administrators to control app installation and management through Samsung Knox Manage. This means that your company's IT department may have restrictions on which apps you can install.
- *Software Updates:* The Enterprise Edition receives regular security updates and maintenance releases for up to 5 years, ensuring that your device stays secure and up-to-date.
- *Google Play Store Access:* The Enterprise Edition does have access to the Google Play Store, but your company's IT department may have restrictions on which apps you can download and install.
Overall, the Samsung Galaxy S24 Ultra Enterprise Edition is a great option for business use, offering enhanced security, management, and productivity features. However, it's essential to check with your company's IT department to understand any specific restrictions or policies regarding app installation and usage.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots. Thank you 😊
LOKESHTEJAVATH
It would not be linked with my it department, when I buy one, so then can I have complete access over it?
Wodehouse
Yes ofcourse and you will get Additional security; remember "Blackberry" of yester years ?. Blackberrys were preferred by CEOs and security dependent people like presidents and high profile politicians.
cs_member10
Dear Samsung Member,
We request you kindly share the log file and elaborate on your concern in detail. Also, share screenshots and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application(Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
