Diagnostics shows batery life as low even after replacement
(Topic created on: 08-14-2022 06:46 AM)
vicascharles
Samsung members app test shows that my Samsung s20 battery needs replacement even after i got it replaced two days ago. Samsung service center, Udupi, India guys said if i format the device once it should be fine. So i did that. Yet there is no use. Did samsung service center cheat me??
13 Comments
vicascharles
Still shows this Screenshot_20220814-064221_Samsung Members_62335_1660439541.jpg
souravsrv1176
How much u pay for?
vicascharles
Nearly 3k
deepak0099
Hi, did you get resolution of this issue?
vicascharles
The issue till exist
iamrohitkm
Did you try factory reset?
vicascharles
Yes. I did the factory reset
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
varification
I am facing the same issue today I changed my Samsung Galaxy s10 bettry and still its showing weak battery
Can you please help me what to do now if I do software update also through service center and its not resolved then what to do??
As I saw the above comment and the issue still occurring
