Data or network issues with s25 ultra
(Topic created on: 02-08-2025 11:41 PM)
bnvpk
I have 5g network still i am unable to use data on phone , i will be able to use data for few min and suddenly I can't use data again though it shows full signals, I changed network to 4g and tried Its still same.
I reset all settings and tried, Its still same.
I placed my Sim in another phone and it works fine in that phone.
Kaushik566
Check vo5g icon show in 5g network?
bnvpk
Only once i pull down i can see it , that too whn i turned on data in sim 1, if sim 2 data is used for sim 1 also vo5g option is gone1739074727815.jpg
Kaushik566
Can you see how many carrier aggregation bands are supported in jio 5g by Dial*#0011#
bnvpk
Kaushik566
This code is works fine with one ui 6 but samsung are disable now
bnvpk
Yes bro, there are many bugs in one ui 7 stable version in s25 ultra.
Actuall there's some display issue also
Kaushik566
Bro can you make calls over vo5g network or network switch back 4g check it???
bnvpk
I can make it, if i am using sim 1 data
Kaushik566
Network are stays in 5g not switch back 4g??
bnvpk
It stays on 5g
