Custom notification sound for each application
(Topic created on: 07-16-2025 06:31 PM)
Rahul3150
Custom notification sounds for each app would be a game-changer. It'd help me stay organized and instantly know who's messaging or calling. Please consider adding this feature! It'd make my phone experience more personalized and efficient. Looking forward to this update!"
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help to set Custom notification sound for each application.
To change the notification sound for each app on the device, the option should be enabled first in the notification settings, then you can now see and set the relevant options for each app. Please follow these steps:
1) Activate 'Manage notification categories for each app': Settings > Notifications > Advanced settings > turn On 'Manage notification categories for each app‘.
This will allow you to see the 'Notification categories' option in the each app settings. Then you can change notification sound in each app settings. To seen and change the sound, you need to set the type to ‘Alert’ option.
2) Change the notification sound: Path① : Notification panel > press and hold the pop-up of the app > Settings > Notification categories > select the category > Sound
Path② : Settings > Apps > select the app > Notifications > enable Allow notifications > Notification categories > select the category > Sound [Enable 'Manage notification categories for each app'].
